Re: Farmall 400 Power Steering
Posted by GordoSD on February 02, 2010 at 07:20:14 from (216.106.249.252):
In Reply to: Farmall 400 Power Steering posted by Matt Weltz on February 02, 2010 at 06:13:49:
This is one of those things I don't think you can do from scrtch, the first time. At a minimum you need the char lyn kit instructions and a "complete kit. Problem is there is no complete kit. Find someone who has a 400 with PS and take a lot of pictures. You need a special bracket for the torque generator. Special bracket for the Saginaw pump. The pump. Special coupler that has both side to side and fore and aft play. Exact dimension to cut the forward shaft.
Then you probably will need to put new seals and o rings in the pump and TG.
Or find a friend who has done at least one.
I've seen several "complete" systems, that were removed from salvage tractors sell on ebay for 800 dollars. And they were missing more than a few critical items. I do have a good Saginaw pump if you go that way
Gordo
