Distributor moisture
Posted by Rob in Ore on February 02, 2010 at 17:37:10 from (74.4.183.217):
This is an IH240 with a 12v electronic ignition stored in an unheated barn in Western Oregon. I just replaced my cap, rotor and wires. The previous rotor disintegrated and left a bunch of rust in the cap. I have it back together and it is running fine now. There is a hole in the bottom of the cap to let moisture run out. Should I spray a short burst of WD-40 in that hole occasionally to displace the moisture? If so, before or after running?
