A gauge that reads to 1000psi connected to that hose, or directly to the fitting will tell you the pressure it can produce. Early tractors were limited to about 500psi, (many were refit with higher pressure relief valve parts to make 800psi) later made 800 or so psi. I believe that the lefdt pipe elbow should not swivel, it should be tightened (pipe threads). The fact that the hose stiffens is a good sign. If the fitting will not tighten removal is turning them CCW! Good luck. JimN
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
