Posted by Melvin Ware on February 04, 2010 at 07:51:57 from (4.152.105.134):
I have a 1951 Farmall M with a belly pump. I don't have any hydraulic implements but am considering adding a 3-point hitch. Is there an easy/inexpensive way to check if the pump is working properly before spending the money? I have little experience with hydraulics but was wondering if a gauge would tell me what I need to know or do I need to connect a cylinder?
As a side note, there is a short length of hydraulic hose connected to the left side pressure port and when I engage the hydraulic lever, the hose moves and appears to stiffen.
Also, the left side delayed pressure port is fitted with a plugged elbow that I noticed will swivel 360 degrees. I didn't know if this is normal or if there is a problem with the threads? Don't see any leaks. If this needs to be repaired, is it necessary to remove all hydraulic connections in order to drop the belly pump and if so, how would I best remove this connection assuming it's damaged?
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
