Re: Farmall M Hydraulics Questions
Posted by D Slater on February 04, 2010 at 19:27:42 from (72.65.129.229):
In Reply to: Re: Farmall M Hydraulics Questions posted by Melvin Ware on February 04, 2010 at 18:55:06:
The 1/2 inch pipe elbows and nipples screw dirrectly into pump casting. Made to remove and install from the outside of tractor. If thats the regular fitting that turns without tighten or loosening, something is broke or stripped. If the pump has oil in it, can' understand why oil is not comming out the bottom of clutch housing when hydralic lever is pulled back. With all ports pluged a good pump will load engine enough to notice when pump is engaged.
