I tried antiseize on one and it didn't help. Another think I learned on the viton tip is not to use the needle as a fulcrum for setting/bending the float as the pressure pushes it into the seat. If you need to bend the tab to reset the float, then remove the needle and just use pliers and then check it with the needle in. I also noticed on my float that the needle kinda wallered out a depression in the metal tab area of the float. Used needle nose pliers to flatten that part out again.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
