Re: Wierd thing, pushing snow, Super A
Posted by Brownie 450 on February 06, 2010 at 04:02:59 from (66.43.241.141):
In Reply to: Wierd thing, pushing snow, Super A posted by scott#2 on February 05, 2010 at 21:50:08:
Grab is right with a plastic bag on the distributor--keeps moisture/ snow out. You might want to check your spark plug wires--if they're fairly old, they could be cross-firing. If the snow is blowing that much you should check your oil bath air cleaner for snow/ ice build-up. If necessary, take the cup inside after use to melt the ice/ snow & make sure the cup is clean before adding new oil.
