Wierd thing, pushing snow, Super A
Posted by scott#2 on February 05, 2010 at 21:50:08 from (138.88.71.37):
I was pushing snow for about a half hour when all of a sudden the tractor just stopped running, like it was out of fuel. Dumped sone stabil in and it fired up a few minutes later but quit again. I noticed it would try to fire if I choked it so I figured fuel. I went and got some wd40 and sprayed the cap, coil and wires and it fired right up. I had to spray 4 or 5 times to keep it going until I was finished. Its blowing snow and the ingition was pretty wet the whole time I was running it.
It got to a point where I could tell it was going to die as it would loose power and stumble when you used the hyds or tried to push in 2nd gear. Glad I figured that one out real quick, getting hammered in Md.
Can I dump ispopropal in the tank if I dont have any drygas?
