If spraying the distributor with WD40 makes it run, then why do you insist that you have a FUEL problem???
You have a wet ignition. Nothing is wrong with your gas.
...and bathroom isopropyl alcohol is not drygas. Bathroom alcohol has a bunch of water in it so you'd be defeating the purpose. Use the product that was meant for the job.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
