Re: Sarting Farmall H
Posted by 87nassaublue on February 06, 2010 at 18:51:49 from (72.15.97.115):
In Reply to: Sarting Farmall H posted by Alvin Dick on February 06, 2010 at 17:27:35:
Did you check to see how raunchy the gas is? If your fuel is old, it may have become too volatile. I'd drain and refuel then keep working with it. You might have an intake valve being a little sticky and causing the carb backfire. Have you cleaned out your carb yet?
