Sarting Farmall H
Posted by Alvin Dick on February 06, 2010 at 17:27:35 from (70.100.22.85):
Worked on my H today that has not run for some time. It starts and runs for 2 or 3 seconds and than kind of bacfires through the carb and dies. Start it up again and it does the same thing again. Pulling on the chook helps a little but it dies. What do I need to look at or change? Thanks
