Re: farmall h won't run
Posted by Janicholson on February 07, 2010 at 09:59:23 from (64.61.211.33):
In Reply to: Re: farmall h won't run posted by Glenn Stauffer on February 06, 2010 at 14:05:28:
If it is not fixed, let us know. The ignition switch is push pull, the starter button is hand push high current. If your wire to the ignition push pull is on the wrong terminal of the high current starter switch, it will act like you describe. Jim
