Re: farmall h won't run
Posted by Glenn Stauffer on February 06, 2010 at 14:05:28 from (174.54.78.201):
In Reply to: Re: farmall h won't run posted by El Toro on February 06, 2010 at 13:21:21:
No solenoid used with this starter. The starter has a high amp switch. The distributor does not have voltage when I turn off the ignition switch.
