Re: MW governor?
Posted by Brian Schmidt on February 09, 2010 at 18:36:58 from (69.66.233.155):
In Reply to: MW governor? posted by Zachary Hoyt on February 09, 2010 at 15:19:13:
If you really want to know, just take the cover off. You can't mess anything up. It is just a cover. Nothing will come flying out or pieces won't fall out. If they do, you got bigger problems.
The old notched throttles always slipped. Many folks put the M&W friction throttle on to remedy this.
The governor tube could have the M&W logo, but this would not be necessary as part of the governor work, but most put it on. So not having it on the tube wouldn't mean for certain it is a Farmall gov.
These tractors are pretty snappy. It all depends on the carb and timing settings on if you would be likely to kill it on a cold day running. My experience is most of these old tractors run pretty good with just a basic tuneup. Not alot you can really screw up too bad if you know much at all.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
