856 fuel pump
Posted by david kline on February 11, 2010 at 14:13:38 from (216.37.220.215):
i having problems with it staying running it will start but it dies out and shuts off there is a bolt back fromn injector lines if i loosen that it will rev back up and run normal but it leaks her adeisel what do i do from here any suggestions
