Re: 856 fuel pump
Posted by Allan In NE on February 11, 2010 at 14:29:43 from (148.66.88.254):
In Reply to: 856 fuel pump posted by david kline on February 11, 2010 at 14:13:38:
Dave,
That's because the relief valve is plugged with debris and when you loosen that bolt the built up housing pressure has a place to go.
See the pictures for your first post on page two?
That pump needs a drive ring.
Allan
