Re: Saw-tooth throttle
Posted by Red Mist on February 11, 2010 at 17:51:57 from (67.142.130.14):
In Reply to: Best plug for H posted by sflem849 on February 11, 2010 at 11:12:37:
MisterT said: (quoted from post at 13:19:09 02/11/10) Correct. The Hs and Ms ALL used the sawtooth throttle right up through the Supers and even the SMTA in 1954. The friction throttle is an aftermarket item from M&W but is still available through the aftermarket.
Well, not exactly. When the Supers - at least about the time the stage 2 supers came out - they came with a different version of the sawtooth throttle which had "square" teeth instead of "saw" teeth. Easy to spot from a distance by the "rivet head" on top of the bell. My stage 2 SH and SM both have the square tooth versions. mike
