Re: Farmall 400 TA questions
Posted by CNKS on February 11, 2010 at 18:28:57 from (216.144.104.128):
In Reply to: Re: Farmall 400 TA questions posted by Nebraska Kirk on February 11, 2010 at 17:57:43:
I have never heard of them breaking. I have the opposite problem. Hard to keep the bearing off the fingers on the main clutch on my 460. Some slop in the linkage requires the adjustment to be close. They do not touch at idle, but centrifugal force puts them against the fingers at operating rpm. Check every connection for too much play. One thing you can do is replace all the pins. I also had some of the holes in the clevices filled -- did not completely cure the problem. Although not recommended, you can adjust the fingers, also. You may have to deviate from "by the book" to get it to adjust it right. Just be sure the TA disengages when the main clutch is disengaged. And that it releases when you pull the TA lever back.
