Re: 300U hydro lines
Posted by Janicholson on February 12, 2010 at 05:58:27 from (199.17.6.222):
In Reply to: 300U hydro lines posted by LAH on February 12, 2010 at 04:56:54:
It is either a bad Oringm a cracked fitting to pipe connection, or a cracked pipe. All can be repaired. Removing the fitting from the pipe and having a machine shop tap it for hose fittings will also work.
The steel lines can be adapted for hose connections at the same time. Good hydraulic repair shops can do it easily if given the steel setup, as is. Jim
