300U hydro lines
Posted by LAH on February 12, 2010 at 04:56:54 from (76.205.190.91):
My 300 utility has solid hydo lines to the pump and they leak at the pump. I've seen on the 350U where they have put a diffrent fitting on the pump with rubber hoses between the pump and the steal lines. I need to find that fitting with the rubber hoses.
