560 diesel/ loader with tranny oil level problem
Posted by Nolan Jae on February 12, 2010 at 06:35:04 from (97.127.91.58):
IH 560 diesel. I have a good sized owantonna loader on the front of my 560 diesel which was purchased with my hobby farm. The loader does not have numbers ect. I changed trani fluid and put it the the required level. No problems/easy work until I want to use the loader. It's not be able to draw enough fliud from the tranny and it will not move the loader much. So I continued putting in tran fluid until the loader works (about 1 and a half additional gallons). Couple questions for those of you who know.
1) the high tran fluid level is leaking some out of the rear pto pressure valve. Is the extra oil gonna hurt the tractor
2) tractor has a schwartz wide front which appears to raise the front end too much and might push all the trany oil back and away from the pick up.
3) can I buy a hydralic tank/resevour and mount to the loader/ tractor/ to give the loader what it needs and not overfill the tranny?
4) could something inside the tranny be rusted through which wont allow the oil to be picked up unless it is over full?
