Re: 300U hydro lines
Posted by pete 23 on February 12, 2010 at 11:02:46 from (173.87.0.197):
In Reply to: 300U hydro lines posted by LAH on February 12, 2010 at 04:56:54:
The solid lines have a bad habit of cracking just where they go into the block that bolts onto pump and at the reservoir. A set with hoses are much better but finding them may be difficult. There are some repair parts that will clamp onto the pipes with a ferrel type compression fitting.
