Posted by John T on February 13, 2010 at 12:51:41 from (71.55.31.109):
In Reply to: 12 volt starter button? posted by Zachary Hoyt on February 13, 2010 at 09:53:42:
I strongly suspect those mechanical push direct start switches (i.e. the ones that carry full starter current with two big terminals, NOT relays, often pedestal mounted like on IHC's) are the same regardless if for 6 or 12 volt BUTTTTTT they could be heavier and more current rated if for 6 volt as they can carry more starter current then 12 volt systems. FWIW Alllllll Ive ever seen are for use on EITHER 6 OR 12 VOLTS.
If smoking from inside they may well be bad as the contacts get all burned and carboned and pitted and develop resistance. To be safe Id still first remove n clean n wire brush each n every starter n switch and battery and ground cables and try her again as if one is resistive it can be problematic. If that fixes the smoking woooooo hoooooooo
I like 0 or better yet 00 gauge cables on 6 volt systems
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
