Thanks for the response. I didn't see your note till now. I took the box off each tractor, pulled the switch and opened up the little tabs that hold it shut, and ended up using the button assembly off the parts tractor and the two bolt assembly that was on the one that smoked. I also cut off and replaced the connector on the end of the wire from the battery and now it works fine with no smoke. The tractor's been converted to 12V, so I had wondered if the double voltage was hard on the switch, but it sounds from you and Old like they're all the same anyway. I had to get it started tonight to move it away from the wall so I can replace the right side rim and tire. Thanks again. Zach
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
