Posted by Dave H (MI) on February 14, 2010 at 08:26:48 from (64.12.116.73):
In Reply to: 1950 Cub,lights posted by Dougct on February 13, 2010 at 15:41:06:
What Gene says. Since it is absolutely possible to have good lighting on a six volt system it is up to you to get it there. The one big issue to check is the connections in your electrical system. Make sure your wiring is good and the right gauge. Go thru it component by component and clean every connection. Be sure to identify how each component grounds and clean those grounds. Having done that it is a good idea to check on the genny. Tractor lights put a major load on the charging system and may require some adjusting. If you have a good ammeter try it for yourself. Run the tractor with lights off and then turn them on while watching the ammeter. The drop in charge can be dramatic. In times when you are using the lights a lot it may be necessary to adjust your genny up a bit, if possible. You need to keep the charging rate up to avoid discharging the battery. Don't want it up too much or you may overcharge and heat up the genny. Once adjusted you will want to keep the lights on all the time. On my plow tractor I keep a screwdriver in the toolbox and adjust the genny to a good charging rate as needed. I figure that is why they put a gauge on the tractor and an adjustment on the genny...so I would be able to keep it where it should be.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
