Re: Is this normal for Farmall 340?
Posted by D Slater on February 15, 2010 at 18:22:09 from (72.65.152.148):
In Reply to: Is this normal for Farmall 340? posted by Pete7 on February 15, 2010 at 17:49:16:
Thats normal if the T/A is good. Move the T/A handle to low setting and the engine should turn both ways. When you put the clutch pedal down all the way that releases the T/A clutch also.
