Re: Is this normal for Farmall 340?
Posted by Pete7 on February 15, 2010 at 19:09:39 from (72.65.47.188):
In Reply to: Re: Is this normal for Farmall 340? posted by D Slater on February 15, 2010 at 18:22:09:
Thanks for the help. The TA is still a new big mystery to me. I'm probably going to put a new clutch (not the TA clutch) in while I'm doing the rear crankshaft seals so I likely will have more questions.
Pete
