Re: Boosting coil voltage during starting
Posted by Bob M on February 16, 2010 at 09:39:47 from (151.190.254.108):
In Reply to: Re: Boosting coil voltage during starting posted by John T PS on February 16, 2010 at 09:05:27:
You've got it John!
The Chrysler ballast resistor accomplishes exactly the same thing by coiling the thermal resistance wire inside a hollow ceramic block.
I've got a Chrysler resistor on my 12 volt converted Super M. It shows only a few tenths of an ohm cold. But it ramps up to ~1.5 ohms after it's run a couple minutes. (The resistor gets quite hot BTW - enough to burn off any oil etc. that finds it's way onto it.)
This post was edited by Bob M at 11:10:52 02/16/10.
