Stop how you are doing it, because it will break the bull pinion carrier. In order to remove the carrier, you need to remove the bull gear from the axle, otherwise the carrier will catch on the bull gear and break off part of the back side that holds the inner bearing in the carrier. If you really want to continue, the easiest way is to jack up the axle housing, remove the PTO, and rear wheel. Remove the bolt inside the trans that holds the bull gear to the axle, remove the axle cap and pull the axle out. This will also give you a chance to inspect the axle bearings, and replace the axle felt and oil seal. After the axle is out, and the bull gear moved out of the way, then remove the brake and bull carrier from the tractor.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
