Re: 1943 Farmall M Brake drum shaft seal housing removal
Posted by IndiRon on February 16, 2010 at 15:34:12 from (76.240.204.202):
In Reply to: Re: 1943 Farmall M Brake drum shaft seal housing removal posted by nosih on February 16, 2010 at 09:43:43:
I agree, I"m restoring a 42 M. Last week I did just what you advised. Removed axle & removed PTO, lifted Bull Gear out and then pulled out brake housing. Oh, I had removed transmission cover a couple weeks earlier...it is very heavy so have a engine hoist to do the lifting.
