The 6,9,14,18 all use the same mechanics, albeit in different diameters and depths. A slipper can be a problem, and is not likely the oil that is the main problem. Stack height is more important, as is spring pressure, which fades over time.
Trying the solvent may help, but I have to say it isn't too likely. A side problem is that if the seal is wore out (likely) then it will leak solvent into the main gearbox. To top it off, the clutch itself can only be partly submerged before fluid will come out places you haven't thought of, like the brake linkage ports. The clutch packs themselves are very thick and without some agitating the solvent will never get deep inside the pack. When you get it apart the standard utterance is "oh, now I understand". To help penetration, driving it around with solvent is one approach. A better one is to open the clutch and pipe solvent horizontally into the exposed edge of the outer drum near the top. It will run out the bottom. Collect clean and recirculate. Warning, there is a lot of crud in these compartments. :roll:
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
