Re: H rear wheel centers rusted on
Posted by glennster on February 18, 2010 at 17:42:38 from (99.90.9.153):
In Reply to: Re: H rear wheel centers rusted on posted by Zachary Hoyt on February 18, 2010 at 17:33:10:
where abouts you located zach? anywho regarding the torch, back the regulators out till the pressure is off the handles, all knobs on torch closed. since you are just heating and not cutting, slowly open the oxy bottle till pressure shows on the gauge, then open cylinder all the way. on the acetlyene, slowly open about 3/4 turn or so. turn pressure regulator in on acetylene till you get about 7 pounds pressure, then set the oxy at about 15 pounds. crack the acetly valve on the torch head just a little and light torch. open some to get some flame, then slowly open the oxy valve and adjust till you get a good flame with a sharp inner cone, no feathers. that will be a neutral flame. you can readjust fuel and o2 from there for more heat.
