Posted by d. coleman on February 18, 2010 at 19:03:33 from (24.249.88.34):
is the pulley a "press fit only" or is there a bolt installed in crankshaft end after installing the pulley? the shop manual isnt clear on wheather to remove a retaining bolt prior to using a puller to remove the crankshaft pulley. thanks, d. coleman
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
