Re: cub crankshaft pulley removal.
Posted by Haas on February 18, 2010 at 19:14:47 from (75.234.26.68):
In Reply to: cub crankshaft pulley removal. posted by d. coleman on February 18, 2010 at 19:03:33:
The crankshaft pulley is a press fit. There is not a retaining bolt. There is a threaded hole in the end of the crankshaft. On my cub, I used that to press the pully back on. When you remove the pulley, you must use a puller that bears against the hub of the pulley. If you pull against the flange, you will break it. Search the archives here. There is a lot about this subject, some show photos of puller designs for this job. Most show using a hydraulic jack, but I used threaded rods on mine and it worked fine.
