Re: Running hydraulic pump off M belt pulley
Posted by Spotted Horse on February 19, 2010 at 20:24:16 from (24.225.2.102):
In Reply to: Running hydraulic pump off M belt pulley posted by oak on February 19, 2010 at 16:40:38:
glennster said: (quoted from post at 21:03:41 02/19/10) the welder is 260 amp at just about full throttle on the belt pulley. has a high and low range and 4 position heat selector, so you say has an 8 speed. by varying the engine rpms and chosing your settings, you pretty much have a full heat range. as long as you run low rpms, i would think you can run the 540 pump off the belt drive.
Glennster, I was thinking about using the hookups from the belt pulley drive, to raise my PT-10 Heston swather when cutting hay,... and may even attempt to run a JD 510 roundbaler off of the pump. I suppose I could experiment with "idleing down" when raiseing the swather, and while tying and dumping bales.
I just thought there might be less to worry about if I used a 1000 rpm pump.
Thanks for your thoughts on what I'm trying to do.
