Posted by Tim Mahony on February 20, 2010 at 16:27:29 from (121.217.98.17):
On a cool morning my tractor will not have power steering or decent brakes and the TA will not change. It feels like the pump is not pumping.Generally, if I leave it at fast idle and engage the hydraulic levers it will all come good after 10 to 20 minutes. I have recently found by removing the plug for the Control valve Oriface and turning the motor over for a bit until oil comes out, then replacing the plug it will work fine.I feel the pump is ok as everything performs well once it starts working.Is an airlock a likely problem? How hard is it to remove the control valve oriface? I tried doing what the book suggests and had no luck. Could it be missing? I performed a pressure test when steering was working and it met all the specs.Any suggestions???
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
