Re: Steering Gearbox Cover Bolts Rub Grille on 47 M
Posted by F-Dean on February 21, 2010 at 04:56:22 from (75.205.206.80):
In Reply to: Steering Gearbox Cover Bolts Rub Grille on 47 M posted by keithg on February 20, 2010 at 21:35:53:
Loosen the bolts holding down the radiator, loosen the hose connections (after draining the radiator), and use the rear support rod to push the radiator forward enough to clear the steering gear box.
Then retighten the bolts, hoses and refill the radiator.
This will also move the hood forward so it is not wearing into the breather pipe.
