Posted by Dellbertt on February 21, 2010 at 06:18:58 from (209.172.22.19):
About the only time I get stuck with my 300U pushing snow is when I am backing out of a push on frozen ground. I just can’t get any traction and just set there spinning.
I used to leave the power up and try to rock or power my way out. That doesn’t work on frozen ground so I would have to throw chains under each wheel and eventually would get enough traction to back out. I also used boards, carpets, old tires, whatever worked to throw under the tires.
I discovered something recently that some already know and maybe some don’t.
I reduced the power to idle and let the tires spin slowly while alternating applying left brake and then the right. The tractor would slide sideways towards the tire that was braked. I was slowly rocking the tractor from side to side until it found some traction and back out on its own.
It has worked every time so far.
The trick is to reduce the power to idle so the tires have time to find some traction.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
