Posted by Leo S on February 21, 2010 at 11:48:57 from (24.220.77.15):
In Reply to: Snowplowing Tips posted by Dellbertt on February 21, 2010 at 06:18:58:
I think it takes a combination of several things. Weight, chains, power, and experiance. Here in South Dakota, we get lots of experiance with moderate to heavy snowfall over the course of years. The snow isn't so bad, but as many of you stated, ice just sucks. We seem to get a bit of ice each year either before the snow starts or sometime during the winter. My snow-plowing rig is a Super MTA with a Dual 325 loader with 7 foot bucket. The tractor has 15 inch tires, aggresive chains and 5 wheel weights per side. I have pushed snow on good ground with less weight and no chains with no problems. However, if there is any ice at all, chains are a must and the additional weight helps. I know that I couldn't do anything on ice without the chains. I have just spun the tires before when on ice while trying to move the tractor with the loader UP AND EMPTY. When pushing the snow I use the highest gear I can without choking off the tractor. This balance between power and speed helps alot with traction. And as mentioned already, There are still times when I have to use the bucket to push my way out of a tight spot. Personally, I like to push snow and run a loader, but I don't like to do it in sub-zero weather when the wind is blowing! My two-cents worth. Leo
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
