Posted by Wardner on February 21, 2010 at 11:17:02 from (4.154.241.138):
In Reply to: 450 LP head again posted by Blackland Dan on February 21, 2010 at 10:37:40:
These are Nebraska test results.
450D 48.78 hp
450LP 54.12 hp
450G 55.28 hp
As for using the proper manifold, one would have to say it should improve performance. But will it be cost effective? IH thought so as they came out with special LP manifold before producing the LP head. I guess they figured "more bang for the buck".
This post was edited by Wardner at 11:20:42 02/21/10.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
