Posted by Brownie 450 on February 22, 2010 at 03:16:17 from (66.43.241.141):
In Reply to: Dead M, I killed it,,,, posted by Jim in Michigan on February 20, 2010 at 15:58:03:
Do you have the clutch blocked ahead/ released when you are trying to turn the engine? Before pulling the pan, I'd block the clutch ahead & remove the starter & try to move the flywheel with a large screwdriver using not much force. Alternatively, jack up a rear wheel & try rocking the wheel with the tractor in high gear.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
