Re: Farmall 450 (gas) Water in Oil pan
Posted by Nebraska Kirk on February 22, 2010 at 19:02:09 from (207.91.4.226):
In Reply to: Farmall 450 (gas) Water in Oil pan posted by rumplestiltskin on February 22, 2010 at 18:47:17:
I think it is just condensation. It would be green if coolant was leaking into the oil pan, assuming you have antifreeze in the radiator.
This post was edited by Nebraska Kirk at 19:02:43 02/22/10.
