Farmall 450 (gas) Water in Oil pan
Posted by Tony_Idaho on February 22, 2010 at 18:47:17 from (71.220.154.183):
OK, just want to get all the possible scenarios before diving in. I was starting to drain the Oil, when the plug was almost out, it started dripping. Clear water, about 1/2 cup. Then the rest of the 2 gallons was a light tan color.
I'm thinking Head Gasket, but want to make sure I check all other possibilities that are easier.
Any easier gaskets to check? :o)
Thanks
Tony
