Re: Farmall 450 (gas) Water in Oil pan
Posted by redgems on February 22, 2010 at 19:04:00 from (68.24.124.208):
In Reply to: Farmall 450 (gas) Water in Oil pan posted by Tony_Idaho on February 22, 2010 at 18:47:17:
I don't want to bring bad news . I have a 400 that I rebuilt. Had the head to machine shop did the whole nine yards on it. 6 months later, to change oil; same as yours, 1/2 cup water with anti freeze in it. Turned out to be crack in head along valve guide unrepairable in my case.Very fine crack not visible with magnuflux only with pressure test. Hope yours is gasket but these farmall heads seem to like to crack. Good luck let us know what you find. Tony
