Re: Farmall 450 (gas) Water in Oil pan
Posted by Erik Dekeyser on February 22, 2010 at 19:12:39 from (161.216.0.20):
In Reply to: Farmall 450 (gas) Water in Oil pan posted by Tony_Idaho on February 22, 2010 at 18:47:17:
How long ago did you change the oil? I think its just condensation also. If you havent changed the oil in a year or two or if you never get the tractor real hot i would think its just condensation.
