Re: Farmall 450 (gas) Water in Oil pan
Posted by NawlensGator on February 23, 2010 at 09:19:29 from (52.129.12.52):
In Reply to: Farmall 450 (gas) Water in Oil pan posted by Tony_Idaho on February 22, 2010 at 18:47:17:
Could be condensation. If the rest of the oil was tan I bet it's a head gasket, the water/oil was emulsified, then some of the water settled out over time. Change the oil, run it, and recheck before doing the head gasket. I had water in my oil and a new hd gasket fixed it.
