Baffled by Independent PTO
Posted by Pete7 on February 24, 2010 at 17:20:09 from (72.65.47.188):
So I figured I'd be able to tell how the engne power was always transmitted to the independent PTO when I split the tractor (Farmall 340) for a clutch replacement. But darn, I can't figure it out. I see the transmission input shaft has a inner and outer splined shaft. And I see where the very center of the shaft is smooth and fits into the pilot bearing on the flywheel. But how is the power being transmitted to the PTO when the clutch is disengaged?? Seems like nothing on that input shaft would turn when the clutch disc isn't being pressed against the flywheel.
Pete
