Re: Photos of Injectors and (Inadequate) Puller
Posted by D Slater on February 27, 2010 at 15:34:05 from (72.65.132.209):
In Reply to: Photos of Injectors and (Inadequate) Puller posted by sflem849 on February 27, 2010 at 09:38:07:
See I have a failure to communicate. Never thought about the injectors you have. I have only removed the nozzle body on other type injectors used on a MD with the slide hammer I made. You have the type that came on one with a engine # 14500 or lower. Later type its easy to remove the nozzle fitting then bolt the plate to nozzle body.
I measured what I made, 5/8 plate 3/4 rod, 56 inches long, 22 lb hammer. Just made it from stuff I had handy. If I was doing another I would drop to 1/2 or 5/8 rod and a lighter hammer and shorten it up at least a foot. Thats just the way I remove the hard ones, i'm sure someone else may have a better idea. Never had one with the type injectors you have, so have no first hand knowledge.
