Re: 12 Volt Conversion
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Rich on May 03, 2000 at 04:42:30 from (207.177.23.66):
In Reply to: 12 Volt Conversion posted by Case on May 02, 2000 at 20:02:03:
Sounds like you went to a lot of work. All you needed was a resistor for your existing coil. Usualy when they are first started the amp. gauge will peg clear over and then work back to about 5 amps.
Post A Followup
: Re: Re: 12 Volt Conversion
