12 Volt Conversion
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Case on May 02, 2000 at 20:02:03 from (208.191.76.67):
I converted my Farmall to 12 volt using the Napa IC14SB coil and the Napa KSI32 switch. It charges just fine and the amp meter jumps to 10 amp which seems high. The alternator is the 10-Si. The ohm reading across the coil is 3.1 to 3.5 cold.
The coil seems to get very hot, is this normal?
Thanks,
Case
Post A Followup
: Re: 12 Volt Conversion
